Re: Writing workflow fragments [message #41831 is a reply to message #41804] |
Mon, 27 April 2009 13:52 |
Johan Wannheden Messages: 40 Registered: July 2009 |
Member |
Hi Sebastian,
yes, I do get the error in the MWE editor. Unfortunately I also get
errors when executing the workflow, but those might be due to other
problems. If I understand your reply correctly the MWE editor error can
safely be ignored, and that information already helps me a lot.
I am using M6a (0.7.0.v200904130430) and looking forward to the error
reporting updates :-).
Thank you,
Johan
Sebastian Zarnekow wrote:
> Hi Johan,
> I guess you get this error in the MWE editor? When you try to execute
> the workflow, it runs fine, doesn't it?
> The error reporting of the MWE editor has been refactored a lot in the
> past weeks. What version are you using?
> Sebastian
> Am 27.04.2009 13:57 Uhr, schrieb Johan Wannheden:
>> Hi all,
>> in order to generate some additional code for my Xtext project I'm
>> trying to implement a fragment that is called upon execution of a MWE
>> workflow file. I get the following error message dialog when entering
>> the fully qualified name of the fragment class to be loaded:
>> An internal error occurred during: "parsing document".
>> Cannot find type 'AbstractGeneratorFragment'
>> Apart from implementing the Java generator fragment class and Xpand
>> template, what exactly needs to be done in order to run a custom
>> workflow fragment?
>> Regards,
>> Johan
Re: Writing workflow fragments [message #41860 is a reply to message #41831] |
Mon, 27 April 2009 14:49 |
Hi Johan,
if you would like to use the latest Integration build, just add
http://download.eclipse.org/modeling/tmf/updates/interim/ Update Site to
your Update Manager.
Dennis.
Johan Wannheden schrieb:
> Hi Sebastian,
> Thank you,
> Johan
>> Hi Johan,
>> Regards,
>> Sebastian
>>> Hi all,
>>> workflow fragment?
>>> Regards,
>>> Johan
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
FUDForum. Page generated in 0.03460 seconds
