Can't create connection [message #41704] |
Wed, 13 November 2002 08:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ademuyser.rational.com
Sorry for the newbies question.
I'm working on an example build upon shapes example.
Now I want to connect EditPart together: Using a
ConnectionCreationTool, defining my XXNodeEditPolicy
and installing it as a NODE_ROLE; having a Wire class
in my model and a WireEditPart ... and so on.
So, now I can start a connection on a EditPart with
a good ConnectionAnchor location (!great), extend the (dummy)
connection to an other EditPart, when I click
the dummy connection is erased and no Connection is created
(no WireEditPart object is build), no call to createConnection()
in my top-level EditPart class is done.
The question is, what is the silly-beginner error I make ?
What is the piece of code I forgot to write ?
Any idea will be very usefull, thanks in advance.
Arnaud.
Re: Can't create connection [message #43554 is a reply to message #41704] |
Tue, 19 November 2002 13:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Still stick on this problem.
I know now that the CreateConnectionCommand is executed and my
Wire's model is connected to existing source and target. Both
selected by clicking on EditPart.
During the connection creating process a dummy connection can be
view in the diagram, but this connection is deleted at second
click time.
It appear that no WireEditPart is created (tracked at Factory).
Do I create a WireEditPart inside my NodeEditPolicy ?
Or do I call any refresh() or other method to force the creation
of a WireEditPart for the connection ?
Does anybody have an idea ?
Arnaud.
Re: Can't create connection [message #43585 is a reply to message #41704] |
Tue, 19 November 2002 15:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Was a command executed?
Your Node EditParts are the only thing that exists. Therefore, they must
listen to the model, and call its own refreshSource/TargetConnections()
method when the node's model is attached to the connection.
> Arnaud.
Re: Can't create connection [message #43705 is a reply to message #43585] |
Wed, 20 November 2002 10:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Great!
That is exactly I forgot in my code, to fire when a connection change in
the model ... and it's handling in the viewer side.
Like the Logic example show me ... if I wasn't blind; sorry.
Many thanks for the help.
Arnaud.
>>Arnaud.
FUDForum. Page generated in 0.03555 seconds
