Home » Eclipse Projects » Eclipse Platform » Jalopy plugin under Eclipse 2.1
Jalopy plugin under Eclipse 2.1 [message #41547] Wed, 21 May 2003 11:28 Go to next message
Originally posted by: m_heisterberg.hotmail.com
Anyone having the Jalopy plugin working under Eclipse 2.1 ? If yes - which
version.
Thanks - lekkim
Re: Jalopy plugin under Eclipse 2.1 [message #41565 is a reply to message #41547] Wed, 21 May 2003 11:44 Go to previous messageGo to next message
Originally posted by: eglass.eavantia.com
Hi Mikkel,
I have been using Jalopy 0.2.6 Eclipse plugin with no problems under 2.1 for
a while now.
You can get it at http://jalopy.sourceforge.net/download.html.
I hope that this helps.
Eric
"Mikkel Heisterberg" <m_heisterberg@hotmail.com> wrote in message
news:bafnti$8pt$1@rogue.oti.com...
> version.
> Thanks - lekkim
Re: Jalopy plugin under Eclipse 2.1 [message #41583 is a reply to message #41565] Wed, 21 May 2003 11:46 Go to previous messageGo to next message
I was afraid you were going to say that. I'm unable to find the Jalopy
functionality in Eclipse 2.1 whereas I had no problems in Eclipse 2.0. Did
you do anything else than normal plugin installation of copying the
directory to the plugin directory ?
lekkim
"Eric Glass" <eglass@eavantia.com> wrote in message
news:bafojp$9dv$1@rogue.oti.com...
> Hi Mikkel,
for
> a while now.
> Eric
which
> > version.
> > Thanks - lekkim
Re: Jalopy plugin under Eclipse 2.1 [message #41599 is a reply to message #41583] Wed, 21 May 2003 12:14 Go to previous messageGo to next message
Andreas Guther is currently offline Andreas GutherFriend
I do not remember doing any special with Jalopy. You should be able with
a right mouse-click to have an Jalopy entry in the context menu.
Andreas
> lekkim
>>Hi Mikkel,
> for
>>a while now.
>>Eric
> which
>>>version.
>>>Thanks - lekkim
Re: Jalopy plugin under Eclipse 2.1 [message #41658 is a reply to message #41547] Wed, 21 May 2003 12:43 Go to previous message
Originally posted by: jvaldez.mail.com
I was able to install it via the standard plugin mechanism. However
using JDK 1.4.x it nukes my javadoc comments with it's own template.
Since I was unable to find any way to stop this, and because it totally
nuked an entire project, I dumped Jalopy.
> version.
> Thanks - lekkim
Previous Topic:Utility class
Next Topic:(De)Activate a Worbench Window Menu Item
Current Time: Thu Dec 26 17:00:19 GMT 2024
Powered by FUDForum. Page generated in 0.03152 seconds
