Home » Eclipse Projects » DTP » Problem with Data Converter in XML ODA driver
Problem with Data Converter in XML ODA driver [message #40908] Fri, 25 January 2008 15:37 Go to next message
Originally posted by: ciro.cavani.uqbar.com.br
I did an ODA driver bridge for ODA WS Driver, but could not read date
values like 2008-01-25T00:00:00-03:00 from XML (SOAP Message actually).
After some investigation, I think that the problem could be in
DateFormatISO8601 where creanDate don't test for '-':
private static String cleanDate( String s )
s = s.trim( );
if ( s.indexOf( 'T' ) < 12 )
s = s.replaceFirst( "T", " " );
int zoneIndex = s.indexOf( "GMT" );
if( zoneIndex > 0 )
return s.substring( 0, zoneIndex ).trim( );
zoneIndex = s.indexOf( 'Z' );
if ( zoneIndex == s.length( ) - 1 )
zoneIndex = s.indexOf( '+' );
if ( zoneIndex > 0 )
return s;
I fix this problema making the server generate just date part.
Should be "Date" and no "Data" [message #40938 is a reply to message #40908] Fri, 25 January 2008 15:39 Go to previous messageGo to next message
sorry!
Re: Problem with Data Converter in XML ODA driver [message #41061 is a reply to message #40908] Thu, 31 January 2008 02:13 Go to previous messageGo to next message
Lin Zhu is currently offline Lin ZhuFriend
Member
Ciro,
Thank you for the investigation. We will look into this.
Lin
"Ciro Cavani" <ciro.cavani@uqbar.com.br> wrote in message
news:95ac6be40a869a784b85c3b512c71f05$1@www.eclipse.org...
> s = s.trim( );
> if( zoneIndex > 0 )
> return s;
Re: Problem with Data Converter in XML ODA driver [message #41246 is a reply to message #40908] Mon, 04 February 2008 07:04 Go to previous messageGo to next message
Member
Ciro,
Thank you for your input. This is confirmed a bug. Bugzilla bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217640 has been filed to trace
it.
Lin
> s = s.trim( );
> if( zoneIndex > 0 )
> return s;
Re: Problem with Data Converter in XML ODA driver [message #41568 is a reply to message #41246] Thu, 14 February 2008 01:52 Go to previous message
Lin,
Thanks.
Should be "Date" and no "Data" [message #589726 is a reply to message #40908] Fri, 25 January 2008 15:39 Go to previous message
sorry!
Re: Problem with Data Converter in XML ODA driver [message #589768 is a reply to message #40908] Thu, 31 January 2008 02:13 Go to previous message
Member
Ciro,
Lin
> s = s.trim( );
> if( zoneIndex > 0 )
> return s;
Re: Problem with Data Converter in XML ODA driver [message #589833 is a reply to message #40908] Mon, 04 February 2008 07:04 Go to previous message
Member
Ciro,
it.
Lin
> s = s.trim( );
> if( zoneIndex > 0 )
> return s;
Re: Problem with Data Converter in XML ODA driver [message #589950 is a reply to message #41246] Thu, 14 February 2008 01:52 Go to previous message
Lin,
Thanks.
Previous Topic:Test fixture for connectivity extension
Next Topic:DTP 1.6 Source for Builds
Current Time: Mon Jan 13 16:39:31 GMT 2025
Powered by FUDForum. Page generated in 0.04510 seconds
