Re: class-files [message #3565 is a reply to message #3499] |
Fri, 13 September 2002 06:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hcs33.egon.gyaloglo.hu
From the AspectJ Development Guide:
-preprocess:
Don't try to generate any .class files. Generate regular Java code into
workingdir
Uncheck 'preprocess only' to get the .class files.
Csaba Horv
Re: class-files [message #4017 is a reply to message #3695] |
Fri, 13 September 2002 13:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Do you use AJDT 0.5.0 or 0.5.1? In 0.5.0 there is a bug where all .class
files was generated under your workspace directory *even if* your project is
located in somewhere else. They said in 0.5.1 it has been fixed.
There is problems using javac in my machine as well but the built-in
Aspect/J compiler produces the .class files for me (and currently i have no
time to investigate my javac problem).
Csaba Horv
Re: class-files [message #561315 is a reply to message #3499] |
Fri, 13 September 2002 06:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
-preprocess:
workingdir
Csaba Horv
Re: class-files [message #561432 is a reply to message #3695] |
Csaba Horv
FUDForum. Page generated in 0.03556 seconds
