Home » Archived » Memory Analyzer (MAT) » Error running reports on Linux
Error running reports on Linux [message #3425] Wed, 27 August 2008 01:17 Go to next message
Adam is currently offline AdamFriend
I cant seem to run any of the reporting functionality on Linux. It worked
fine on Windows. Is there something different I need to do to get it
working? Appreciate the help, thanks.
btw... product works great.
Running RHES5.
Here's my error stack:
!SESSION 2008-08-26 18:00:37.371
eclipse.buildId=unknown
java.version=1.5.0_11
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui.intro 4 0 2008-08-26 18:00:41.292
!MESSAGE Failed to create the content of Intro model content provider:
org.eclipse.mat.ui.rcp.actions.SnapshotHistoryIntroContentPr ovider
!STACK 0
org.eclipse.core.internal.runtime.Activator.getURLConverter( Activator.java:313)
org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.j ava:164)
org.eclipse.mat.ui.rcp.actions.SnapshotHistoryIntroContentPr ovider.createImage(SnapshotHistoryIntroContentProvider.java: 167)
org.eclipse.mat.ui.rcp.actions.SnapshotHistoryIntroContentPr ovider.createContent(SnapshotHistoryIntroContentProvider.jav a:115)
org.eclipse.ui.internal.intro.impl.swt.PageWidgetFactory.cre ateContentProvider(PageWidgetFactory.java:392)
org.eclipse.ui.internal.intro.impl.swt.RootPageForm.createCo ntentProvider(RootPageForm.java:342)
org.eclipse.ui.internal.intro.impl.swt.RootPageForm.createGr oupContent(RootPageForm.java:273)
org.eclipse.ui.internal.intro.impl.swt.RootPageForm.createRo otPageContent(RootPageForm.java:231)
org.eclipse.ui.internal.intro.impl.swt.RootPageForm.createPa rtControl(RootPageForm.java:193)
org.eclipse.ui.internal.intro.impl.presentations.FormIntroPa rtImplementation.createMainPageBook(FormIntroPartImplementat ion.java:168)
org.eclipse.ui.internal.intro.impl.presentations.FormIntroPa rtImplementation.dynamicCreatePartControl(FormIntroPartImple mentation.java:137)
org.eclipse.ui.internal.intro.impl.presentations.FormIntroPa rtImplementation.createPartControl(FormIntroPartImplementati on.java:99)
org.eclipse.ui.internal.intro.impl.model.IntroPartPresentati on.createPartControl(IntroPartPresentation.java:268)
org.eclipse.ui.intro.config.CustomizableIntroPart.createPart Control(CustomizableIntroPart.java:194)
org.eclipse.ui.internal.ViewIntroAdapterPart.createPartContr ol(ViewIntroAdapterPart.java:98)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:371)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:230)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2127)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1062)
org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.j ava:3773)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3770)
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3746)
org.eclipse.ui.internal.WorkbenchIntroManager.createIntro(Wo rkbenchIntroManager.java:173)
org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(Work benchIntroManager.java:120)
org.eclipse.ui.internal.WorkbenchWindow$20.runWithException( WorkbenchWindow.java:2178)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4021)
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1356)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2312)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at org.eclipse.mat.ui.rcp.Application.start(Application.java:26 )
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.ui 4 0 2008-08-26 18:01:17.953
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/mozilla/javascript/ScriptableObject
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:947)
org.eclipse.mat.ui.internal.chart.ChartCanvas.generateChartS tate(ChartCanvas.java:110)
org.eclipse.mat.ui.internal.chart.ChartCanvas.drawToCachedIm age(ChartCanvas.java:135)
org.eclipse.mat.ui.internal.chart.ChartCanvas.access$1(Chart Canvas.java:120)
org.eclipse.mat.ui.internal.chart.ChartCanvas$1.paintControl (ChartCanvas.java:72)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:217)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1182)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1167)
org.eclipse.swt.widgets.Control.gtk_expose_event(Control.jav a:2703)
org.eclipse.swt.widgets.Composite.gtk_expose_event(Composite .java:669)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Canvas.java: 170)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1539)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4502 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4099 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native
Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:57 83)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1177)
org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1541)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3031)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
!ENTRY org.eclipse.ui 4 0 2008-08-26 18:01:20.973
!STACK 0
Re: Error running reports on Linux [message #3491 is a reply to message #3425] Wed, 27 August 2008 07:54 Go to previous message
Andreas Buchen is currently offline Andreas BuchenFriend
> working?
There should be no difference. I tested it on Ubuntu some time ago and
that was fine. I am firing up my VirtualBox just now to investigate.
I have created this bugzilla entry to track your error report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245347
If you want, you can add yourself as CC to be informed about updates.
Previous Topic:Group by java.lang.ref.Finalizer.referent class name
Next Topic:Namespace reporting is not ebavled
Current Time: Wed Feb 05 12:57:25 GMT 2025
Powered by FUDForum. Page generated in 0.02240 seconds
