Home » Archived » BIRT » DataRow.rowNo how does this work
DataRow.rowNo how does this work [message #39304] Mon, 23 May 2005 14:47 Go to next message
A couple more questions
Q: I'm trying to write some Java script as part of an expression
and I have
var count = DataRow.rowNo;
but I get an error when I go to preview, any ideas why this doesn't
evaluate.
Q: When will the expression editor have intelli-sense, to support Object
available methods and attributes?
Re: DataRow.rowNo how does this work [message #39334 is a reply to message #39304] Mon, 23 May 2005 14:59 Go to previous messageGo to next message
hmmm :| I also tried. from the rom spec
var r = report.dataSets["DataInfo"].row
var rowNumber = r.rowNo
where "DataInfo" is the name of my data set.
and still can't get the row index, any idea how this is done?
Also
> and I have
> evaluate.
Re: DataRow.rowNo how does this work [message #39364 is a reply to message #39304] Mon, 23 May 2005 16:33 Go to previous messageGo to next message
Mike,
I found this same issue and have logged a bug on it. In the meantime
you can use:
row[0] which gets a field that holds a zero based number for the
position of the record in the DataSet.
Scott Rosenbaum
BIRT PMC
> and I have
> evaluate.
> Object available methods and attributes?
Re: DataRow.rowNo how does this work [message #40661 is a reply to message #39334] Tue, 24 May 2005 19:05 Go to previous message
Mike,
As Scott pointed out, the team decided to drop the name alias for the row
number column out of concern for the "rowNo" name clashing with a real
column name. The data row is an array of values, and allows both numeric and
string indexes. Even though the "rowNo" string index is not available, you
can use the numeric index: row[0]. (Columns from your data set are defined
to start with index 1, so BIRT reserves index 0 for the row count.)
On intellisense; the UI team is looking at possible projects for the next
release and intellisense is on their list. However, at this point, no post
1.0 feature list is yet available, but watch for the candidate list in the
coming weeks.
- Paul
Paul Rogers
BIRT PMC
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:d6t9bd$euh$1@news.eclipse.org...
> Also
>> and I have
>> evaluate.
Previous Topic:combining rowset data with text using java script when and where is it legal, and on what elements?
Next Topic:Scripting which images to include in my report
Current Time: Fri Apr 18 21:33:30 EDT 2025
Powered by FUDForum. Page generated in 0.04157 seconds
