Re: Repository Structure [message #41093 is a reply to message #40941] |
Thu, 05 February 2009 14:28 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello Pete,
As I remember we fixed the similar problem, please, update to latest version
and try again.
My email: igor.burilo@polarion.org
> Hello Igor
> Thank you for the response. I got a new, empty repository and tried to
> reproduce the problem with a simple structure similar to the complex one
> (many components and code) we use. But I was not able to reproduce it
> there.
> We have no .project files in the repository as they are generated by the
> build system. Could this be a problem in this case?
> I called the action "New->Tag..." in the view "SVN Repository Exploring
> perspective" in "SVN Repositories" on the component-folder.
> Could you give me your email-address in order that I can send you
> screenshots?
> Unfortunately, it is not possible to give you access to our repository, I
> checked this.
> Kind Regards
> Pete
> Igor Burilo wrote:
>> Hello Pete,
>> It could be a bug, so could you please provide additional information?
>> I'm interested in your exact repository structure, especially .project
>> files (it's important), and on which folder you called the action.
>> Probably it would be better to make a screenshot of you repository which
>> includes your 'components' folder (this is from your example) with all
>> expanded sub-folders and root folder with trunk/branches/tags.
>> It would be great if you can provide an url to your repository (of course
>> if it's possible) and I can test it.
>>> Hello Igor
>>> Thank you for your help.
>>> The version of subversive is 0.7.5.I20081029-1900 with connector "Native
>>> JavaHL (svn:1.4.5 (r25188) jni:0.9.0)" and eclipse "3.3.2 Build id:
>>> M20080221-1800". Yes, we have enabled "Respect project structure" in the
>>> preferences.
Re: Repository Structure [message #41392 is a reply to message #41093] |
Mon, 09 February 2009 07:06 |
Pete Messages: 6 Registered: July 2009 |
Junior Member |
Hello Igor and snop3
Thanks you for this hint, I installed the new version and did not any more
experience the problem. It is still under test now and I hope the problem
is not reproducible.
Thanks for the email-address, I send you screenshots only if the problem
occurs again.
Kind regards
Pete
Igor Burilo wrote:
> Hello Pete,
> and try again.
>> Hello Igor
>> there.
>> screenshots?
>> checked this.
>> Kind Regards
>> Pete
>> Igor Burilo wrote:
>>> Hello Pete,
>>>> Hello Igor
>>>> preferences.
FUDForum. Page generated in 0.08092 seconds
