| CDT build error [message #39201] |
Mon, 05 August 2002 20:30  |
All,
While trying to build the Windows version of CDT following the
"Developing the CDT" documentation, I have run into the following
build error:
This compilation unit indirectly references the missing type
java.lang.Object
(typically some required class file is referencing a type outside the
classpath) Color.java
org.eclipse.swt/Eclipse SWT/carbon/org/eclipse/swt/graphics line 1 in
org.eclipse.swt.graphics
Any idea what could be the problem?
By the way, I am a Java newbie so don't shoot me for being somewhat
"ignorant".
Art
| Added plugins and now OK [message #39354 is a reply to message #39324] |
Thu, 08 August 2002 14:31   |
Judy,
I added the required plugins as External Packages and/or Fragments as
explained in
the revised "Developing the CDT" document and, voila, everything is OK.
m.
"Mas Yokota" <myokota@unitech.com> wrote in message
news:airtvr$g3a$1@rogue.oti.com...
> Judy,
> Thanks for your help, but I am still having problems building CDT on a
> Windows 2000 system.
> I did as follows:
> 1. Checked out CDT projects from CVS. After project builds, 10 or so tasks
> appeared in the task view. e.g.
> "Missing required Java project: org.eclipse.swt" etc..
> 2. So checked out these projects from CVS. These checkouts caused more
> "missing required Java project." tasks.
> 3. Eventually, a task appeared for Color.java for which I have no idea
what
> to do.
> java.lang.Object (typically some required class file is referencing a type
> outside the classpath) Color.java org.eclipse.swt/Eclipse
> SWT/carbon/org/eclipse/swt/graphics line 1 in org.eclipse.swt.graphics
> m.
> "Judy N. Green" <jgreen@qnx.com> wrote in message
> news:aiolgs$pee$1@rogue.oti.com...
> > Hi Mas,
> > Which projects did you check out of the CVS repsository?
> > What platform are you running one?
> > You only need the following cdt projects:
> > org.eclipse.cdt.core
> > org.eclipse.cdt.ui
> > org.eclipse.cdt
> > org.eclipse.cdt.core-feature
> > org.eclipse.cdt.debug
> > org.eclipse.cdt.debug.mi.core
> > org.eclipse.cdt.debug.ui
> > -Judy
> > news:ain53a$3c9$1@rogue.oti.com...
> > | All,
> > | build error:
> > | java.lang.Object
> > | "ignorant".
> > | Art
| Re: Added plugins and now OK [message #39507 is a reply to message #39354] |
Fri, 09 August 2002 16:06  |
Hi Mas,
Sorry for the confusion,
We left out that crucial step in the first revision of the docs.
Glad to hear you are having better luck. :)
-Judy
news:aiud37$pb6$1@rogue.oti.com...
| Judy,
| explained in
| m.
| > Judy,
| > I did as follows:
tasks
| what
| > to do.
type
| > m.
| > > Hi Mas,
| > > org.eclipse.cdt.ui
| > > org.eclipse.cdt
| > > -Judy
| > > | All,
| > > | build error:
| > > | java.lang.Object
the
in
| > > | "ignorant".
| > > | Art
FUDForum. Page generated in 0.04747 seconds
