Re: NIST errors when running MESA test 11746 [message #39073 is a reply to message #39040] |
Mon, 17 December 2007 23:08 |
Jyran Glucky Messages: 14 Registered: July 2009 |
Junior Member |
Sorry guys,
DFU error. I was using the registry not the repository. DOH!
Thank you,
Jyran Glucky
Lead Architect
BlueWare
Jyran Glucky wrote:
> As a follow up, when I run MESA11746_Option1, I receive the following
> error:
> Errors:copy
> Error: XDSRegistryMetadataError Document
> urn:uuid:66ddee2c-26da-4524-f72f-006073edd28c does not have the required
> slot creationTime Error: XDSRegistryMetadataError Document
> slot hash Error: XDSRegistryMetadataError Document
> slot languageCode Error: XDSRegistryMetadataError Document
> slot size Error: XDSRegistryMetadataError Document
> slot sourcePatientInfo Error: XDSRegistryMetadataError Document
> slot URI
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
> Jyran Glucky wrote:
>> Hi all,
>> I am attempting to run the MESA11746_Option2 test script and after
>> checking my result against NIST, I am noticing the submission shows
>> the following error.
>> urn:uuid:66032850-25fe-4524-ebee-006073edd28c does not have the
>> required slot hash Error: XDSRegistryMetadataError Document
>> required slot size Error: XDSRegistryMetadataError Document
>> required slot URI Error: XDSRegistryMetadataError Document
>> urn:uuid:66032850-25fe-4524-ebee-006073edd28c : Classification of type
>> urn:uuid:f4f85eac-e6cb-4883-b524-f2705394840f ( confidentialityCode )
>> the slot 'codingScheme' is missing Error: XDSRegistryMetadataError
>> Classification
>> (classificationScheme=urn:uuid:f4f85eac-e6cb-4883-b524-f2705 394840f
>> codingScheme=) of object
>> urn:uuid:66032850-25fe-4524-ebee-006073edd28c: Not Found
>> Any idea's?
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare, Inc.
Re: NIST errors when running MESA test 11746 [message #39097 is a reply to message #39040] |
Mon, 17 December 2007 23:18 |
Matthew Davis Messages: 269 Registered: July 2009 |
Hi Jyran,
I believe this is related to the problem we had earlier about targeting
the wrong endpoint for the registry.
http://www.eclipse.org/newsportal/article.php?id=639&gro up=eclipse.technology.ohf#639
The problem was resolved in a bug fix about a month ago, so you might
updating your libraries. Otherwise, please verify that you're using the
proper URL for the registry and the repository.
-Matt
> error:
> Errors:copy
> slot URI
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
> Jyran Glucky wrote:
>> Hi all,
>> Classification
>> Any idea's?
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare, Inc.
Re: NIST errors when running MESA test 11746 [message #583893 is a reply to message #39040] |
Junior Member |
Sorry guys,
Thank you,
Jyran Glucky
Lead Architect
BlueWare
> error:
> Errors:copy
> slot URI
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
> Jyran Glucky wrote:
>> Hi all,
>> Classification
>> Any idea's?
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare, Inc.
Re: NIST errors when running MESA test 11746 [message #583906 is a reply to message #39040] |
Hi Jyran,
-Matt
> error:
> Errors:copy
> slot URI
> Thank you,
> Jyran Glucky
> Lead Architect
> BlueWare
> Jyran Glucky wrote:
>> Hi all,
>> Classification
>> Any idea's?
>> Thank you,
>> Jyran Glucky
>> Lead Architect
>> BlueWare, Inc.
FUDForum. Page generated in 0.03999 seconds
