scrolling constantly reads from disk? [message #38708] |
Mon, 23 July 2007 19:03 |
Originally posted by: sixdaily.gmail.com
Hey, when I try to use a PDT editor to edit files in a remote drive, the
performance is very slow. It seems to want to read and write to the disk
for everything I do, and since the connection is not a super-fast LAN,
even very simple edits are getting very slow. This mainly happens when I
am using the up/down arrows to scroll in the file, or to select a block
of text, but also during other times.
I do have the latest integration build (20070712), is there some way to
turn off whatever is causing the constant read/write to disk?
Thanks for your help!
Kelvin
Re: scrolling constantly reads from disk? [message #38872 is a reply to message #38708] |
Tue, 24 July 2007 11:53 |
Originally posted by: pavel.dvorak.work.gmail.com
Kelvin napsal(a):
> the performance is very slow. It seems to want to read and write to
> the disk for everything I do, and since the connection is not a
> super-fast LAN, even very simple edits are getting very slow. This
> mainly happens when I am using the up/down arrows to scroll in the
> file, or to select a block of text, but also during other times.
> to turn off whatever is causing the constant read/write to disk?
> Kelvin
yes it reads from disk on keypress (doesn't matter if you scroll the
cursor or the window). strange
FUDForum. Page generated in 0.03408 seconds
