Home » Newcomers » Newcomers » Eclipse on Suse Linux 9.1
Eclipse on Suse Linux 9.1 [message #38668] Tue, 22 March 2005 15:52 Go to next message
Originally posted by: whalesuit.bonbon.net
Hi all,
I am trying to run Eclipse on a machine running Suse Linux 9.1, which
seems to ship with Sun's Java 1.4 JDK I have been able to successfully
launch Eclipse this way, but no plugins, wizards, etc appear. For
example, after I create a new project, there is no File->New->Class
option available.
When I attempt to use -configuration option to specify the config.ini
file found in the configuration directory, I get a null pointer
exception. Unfortunately I can't reproduce the specific messages
produced the by exception because I'm at work now, but I was wondering
if anyone has seen anything like this, and if so how they resolved it.
Otherwise, I'll post the the exceptions tonight.
Thanks in advance for any advice.
EE
Re: Eclipse on Suse Linux 9.1 [message #40154 is a reply to message #38668] Fri, 25 March 2005 15:02 Go to previous messageGo to next message
Gernot Veith is currently offline Gernot VeithFriend
Eric E wrote:
> Hi all,
> which seems to ship with Sun's Java 1.4 JDK I have been able to
> successfully launch Eclipse this way, but no plugins, wizards, etc
> appear. For example, after I create a new project, there is no
> File->New->Class option available.
> EE
I'm using eclispe (GTK and Motif) on Suse 9.1 and 9.2 without any problems.
Ensure you've installed the eclipse *sdk*...
AFAIK it doesn't make any difference whether you are using the
IBM or the SUN runtime.
Re: Eclipse on Suse Linux 9.1 [message #44680 is a reply to message #40154] Fri, 01 April 2005 00:20 Go to previous message
Jeff Smith is currently offline Jeff SmithFriend
If yours is working fine, have you ever had an unexpected crash (Exit
code=255) where you lose all changes? That's what I'm getting, and no
relevant action that causes it. Just happens after a while. --jeffs
Gernot Veith wrote:
> problems. Ensure you've installed the eclipse *sdk*...
Previous Topic:Eclipse crashes in Linux
Next Topic:re-create Project fails
Current Time: Sun Nov 10 01:28:01 GMT 2024
Powered by FUDForum. Page generated in 0.06562 seconds
