Expected FS format '2'; found format '3' (Beginners problem Installation) [message #38331] |
Wed, 26 November 2008 14:59 |
Originally posted by: ed_08.tantec.de
today I decided to start using subversion to mangage my C++ projects and
also found subversive.
I installed subversion under Windows XP using file
"Setup-Subversion-1.5.3.msi" (later also tried
"Setup-Subversion-1.5.1.en-us.msi") and it works. Also I installed
subversive and svn connectors and it is available in Eclipse IDE.
I used "svnadmin create" to create a repository and then tried to add
the repository location to subversive, by entering the URL to "New
Repository Location" dialog. This results in following message:
Location information has been specified incorrectly
svn: Unable to open an ra_local session to URL
svn: Unable to open repository 'file:///D:/Daten/SVN'
svn: Expected FS format '2'; found format '3'
What's wrong? Is it a problem of installation or usage?
Thank you,
Ed
FUDForum. Page generated in 0.03389 seconds
