How to get the "real" name of a project [message #38302] |
Mon, 19 May 2003 05:34 |
Originally posted by: chambery.us.ibm.com
Hey all,
I'm trying to save the path of a file in the workspace in a project name
neutral way. For example: if the project name in CVS is "foo" and I
check it out as "foobar", then any references to files in the workspace
are led by "/foobar/...", which makes the reference invalid for other
team members with different names for the same project.
Is there a way to get the "real" name of a shared project?
Todd
Re: How to get the "real" name of a project [message #38369 is a reply to message #38302] |
Mon, 19 May 2003 18:06 |
Originally posted by: richkulp.nos.pam.us.ibm.com
Why are you changing the name of the project? Paths are relative to the
workspace not the project, so you wind up with the name of the project
in the path. It is better to not change the name of the project. It is
also easier for everyone because then when you talk your team mates, you
are using the same names for everything.
Rich
Re: How to get the "real" name of a project [message #38685 is a reply to message #38466] |
Mon, 19 May 2003 21:38 |
You only need the _1.0.0 when actually deploying it as binary to
customers. You don't need your project to be that name during
development. Basically when creating the deployed plugin, your build
process should create a directory with _1.0.0 on it, and then put the
actual built files and jars under it.
If you are using the PDE build process it can do this for you
automatically, especially if you use the PDE feature process too.
FUDForum. Page generated in 0.04300 seconds
