getting following error with report engine API [message #38110] |
Wed, 18 May 2005 13:53 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: vijayanb.gmail.com
hi there,
getting following error with report engine API when executing the example
RunReport.java
please let me know what I am doing wrong..
thanks
vijay
May 18, 2005 9:26:05 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>INFO: Data Engine starts upMay 18, 2005 9:26:05 AM
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask runSEVERE:
Error.OutputFormatNotSupported
Report test.rptdesign run failed.
org.eclipse.birt.report.engine.api.EngineException: The output format html
is not supported.
Re: getting following error with report engine API [message #38470 is a reply to message #38373] |
Wed, 18 May 2005 20:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi wang,
thanks for the pointer...
I am using the the following plugin.xml for fo and html emitters..
BIRT 0.0.1 Nightly Build (Build N <20050501-1926>
is there a newer plugin than this..? Pl let me know..
thanks
vijay
"Stanley Wang" <swang@actuate.com> wrote in message
news:fb688899eda30241d3170372a46efe8a$1@www.eclipse.org...
> Very likely, you have a mismatch of file version. There was a recent
> change to the plugin.xml files for the fo and html emitter plugins. Your
> installed plugins may have the old plugin.xml, while your downloaded
> sources may be assuming new plugin.xml files.
> Stanley Wang
> BIRT Lead
Re: getting following error with report engine API [message #129909 is a reply to message #38110] |
Tue, 14 February 2006 07:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: huy.banh.gmail.com
Hi Vijay,
I am running into this problem, although I have set birt home correctly.
Did you solve this problem? Would you please tell me how did you solve it?
HB.
vijay wrote:
> hi there,
> RunReport.java
> thanks
> vijay
> is not supported.
FUDForum. Page generated in 0.03787 seconds
