Home » Archived » Visual Editor (VE) » Running Frame
Running Frame [message #38019] Thu, 20 May 2004 06:54 Go to next message
Originally posted by: pts.uninova.pt
Hi, I would like some help, if possible
When I run my frame, the swing components donŽt appear.
Can any body tell me why is that?
Thanks, in advance.
Re: Running Frame [message #38051 is a reply to message #38019] Thu, 20 May 2004 08:37 Go to previous messageGo to next message
Are you using an AWT Frame or a Swing JFrame as the container? Please
post a code sample that exhibits your problem.
- Jeff
> Thanks, in advance.
Re: Running Frame [message #38179 is a reply to message #38051] Thu, 20 May 2004 10:36 Go to previous messageGo to next message
This code shows that I am tried to create a frame with a button.
And when I run the code the ContentPane doesn't appear.
Thank you very much.
public class Myframe extends JFrame {
private javax.swing.JPanel jContentPane = null;
private javax.swing.JButton jButton = null;
* This is the default constructor
public Myframe() {
super();
initialize();
* This method initializes this
* @return void
private void initialize() {
this.setTitle("XPTO");
this.setSize(316, 250);
this.setContentPane(getJContentPane());
this.addWindowListener(new java.awt.event.WindowAdapter() {
public void windowClosing(java.awt.event.WindowEvent e) {
System.out.println("windowClosing()"); // TODO Auto-generated Event
stub windowClosing()
System.exit(0);
private javax.swing.JPanel getJContentPane() {
if(jContentPane == null) {
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(null);
jContentPane.add(getJButton(), null);
return jContentPane;
Myframe frame = new Myframe();
private javax.swing.JButton getJButton() {
if (jButton == null) {
jButton = new javax.swing.JButton();
jButton.setBounds(195, 65, 87, 62);
jButton.setText("OK");
jButton.setOpaque(false);
jButton.setVisible(true);
return jButton;
Re: Running Frame [message #38211 is a reply to message #38179] Thu, 20 May 2004 11:02 Go to previous message
Pedro,
You're missing a brace ending the declaration of the main() method, so
the JButton's method declaration is messed up. I'm surprised this code
will even compile.
Note: in your main() method you probably should also add the line:
frame.show();
after the construction of the frame.
Good luck,
- Jeff
> public static void main(String[] args) {
> return jButton;
Re: Running Frame [message #588899 is a reply to message #38019] Thu, 20 May 2004 08:37 Go to previous message
- Jeff
> Thanks, in advance.
Re: Running Frame [message #588953 is a reply to message #38051] Thu, 20 May 2004 10:36 Go to previous message
public Myframe() {
super();
initialize();
* @return void
System.exit(0);
return jButton;
Re: Running Frame [message #588963 is a reply to message #38179] Thu, 20 May 2004 11:02 Go to previous message
Pedro,
will even compile.
frame.show();
Good luck,
- Jeff
> return jButton;
Previous Topic:Running Frame
Next Topic:java.lang.NoClassDefFoundError: javax/resource/ResourceException
Current Time: Fri Oct 17 22:28:24 EDT 2025
Powered by FUDForum. Page generated in 0.04137 seconds
