Home » Language IDEs » Java Development Tools (JDT) » Specify folder in CVS repository
Specify folder in CVS repository [message #37452] Fri, 23 May 2003 16:16 Go to next message
I have a CVS repository, structured like so (starting at CVSROOT)
/Document/whatever
/Java/project1
/Java/project2
I want to put a new project on the CVS Server /Java/project3
So I right click on the project and select Team -> Share Project...
I select Use existing repository location
I select User Project name as module name
Then Next
Then Finish
And I see this:
/Document/whatever/...
/Project3/...
/Java/Project1/...
/Java/Project2/...
which in retrospect, is no surprise, but I want it to be /Java/Project3
How do i do this?
Re: Specify folder in CVS repository [message #37486 is a reply to message #37452] Fri, 23 May 2003 16:24 Go to previous message
oh, i tried specifying the module name with "Java/Project3" and it
created it in the correct place, but the folder Project 3 is empty
> /Document/whatever
> /Java/project1
> /Java/project2
> Then Next
> Then Finish
> And I see this:
> /Project3/...
> /Java/Project1/...
> /Java/Project2/...
> How do i do this?
Previous Topic:Refactor: rename field dosn
Next Topic:accessing non-Java files
Current Time: Fri Apr 25 19:09:57 EDT 2025
Powered by FUDForum. Page generated in 0.03575 seconds
