Home » Archived » Visual Editor (VE) » Problems when vep plugin is modified.
Problems when vep plugin is modified. [message #37080] Fri, 14 May 2004 00:18 Go to next message
Originally posted by: sibin.exorindia.com
Hi Everybody,
I am trying to make some modification in
org.eclipse.ve.java.core.For this purpose I have added a jar file in the
build path of the plugin.During runtime I encountered an
NoClassfoundError.The classes inside the jar file are not detected.I have
tried ,adding the jar file under runtime in Plugin.xml.But still it is not
working.
Hoping to get some help.
sibin
Re: Problems when vep plugin is modified. [message #37182 is a reply to message #37080] Fri, 14 May 2004 08:30 Go to previous message
Originally posted by: mendelgili.netscape.net
sibin wrote:
> Hi Everybody,
> working.
> Regards
> sibin
If you have run the work space before, eclipse is caching reg. info.
Have you tried the -clear option on the Eclipse command line and (the
last resort of) erasing the configuration directory out below the
eclipse directory?
Re: Problems when vep plugin is modified. [message #588581 is a reply to message #37080] Fri, 14 May 2004 08:30 Go to previous message
sibin wrote:
> Hi Everybody,
> working.
> Regards
> sibin
eclipse directory?
Previous Topic:"design-time" bean and a "run-time" bean
Next Topic:Bug in the test scenario
Current Time: Sun Apr 27 02:11:32 EDT 2025
Powered by FUDForum. Page generated in 0.02138 seconds
