How do you make an untracked change? [message #36887] |
Sat, 10 June 2006 00:32 |
Originally posted by: none.unknown.com
------=_NextPart_000_0018_01C68C03.CB4BA280
Content-Type: text/plain;
charset="iso-8859-1"
I want to write to some resources without having the =
TransactionalEditingDomain know about it. Or at the very least, without =
marking the resources as dirty. The change is essentially replacing =
proxies with actual EObjects. Is there a way to do so?
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2873" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I want to write to some resources =
without having=20
the TransactionalEditingDomain know about it. Or at the very =
least,=20
without marking the resources as dirty. The change is essentially=20
replacing proxies with actual EObjects. Is there a way to do=20
so?</FONT></DIV></BODY></HTML>
------=_NextPart_000_0018_01C68C03.CB4BA280--
Re: How do you make an untracked change? [message #36921 is a reply to message #36887] |
Sat, 10 June 2006 03:59 |
Hi, Pratik,
Perform your changes with the Transaction.NO_UNDO,
Transaction.NO_NOTIFICATIONS, and Transaction.NO_TRIGGERS options. If you
think that you may need to make these changes when the calling context has
a read-only transaction in progress, then you would also need the
Transaction.UNPROTECTED option (which actually implies NO_UNDO and
NO_TRIGGERS, anyway, in addition to NO_VALIDATION).
If your resource is tracking modifications (as it would do by default if
you are using GMF), then in order to prevent it becoming dirty, you will
actually have to reset its isModified property. The resource listens
"directly" to its contents using a ModificationTrackingAdapter, so you
can't hide your changes from it.
Do not temporarily disable notification on any object while replacing
proxies in its features using eSetNotify(). This would hide changes from
the ModificationTrackingAdapter, but it would also prevent the
TransactionChangeRecorder from finding out about the new objects attached
to the resource set (esp. in the case of containment proxies). The
consequence would be incomplete change tracking in the future when you do
want it.
HTH,
Christian
marking the resources as dirty. The change is essentially replacing proxies
Re: How do you make an untracked change? [message #580439 is a reply to message #36887] |
Hi, Pratik,
want it.
HTH,
Christian
FUDForum. Page generated in 0.03214 seconds
