AJDT 1.1.10 available (runs on Eclipse 3.0M9) [message #36303] |
Tue, 25 May 2004 08:41 |
Originally posted by: clemas.uk.ibm.com
AJDT 1.1.10 supports Eclipse 3.0M9 - this update will also run on Eclipse
3.0M8.
If you have an update site defined for AJDT then you should be able to
upgrade to this version directly. It is also available as an archive of
plugins for standalone installation without an update site connection.
See our homepage and download page for more information.
http://eclipse.org/ajdt
thanks,
Andy.
AJDT Development
Re: AJDT 1.1.10 available (runs on Eclipse 3.0M9) [message #36613 is a reply to message #36336] |
Wed, 26 May 2004 07:11 |
Michael Moser wrote:
> There seems to be some problem with this download:
> First, it's pretty slow and then I repeatedly got NullPointer
> exceptions while downloading the update (I tried about 5 times so
> far). At some point the download always hangs and a while later some
> message tells about that null-pointer exception and asks whether one
> wants to retry or not.
> There is probably little you can do about this - but I wanted to let
> you know - just in case...
> Michael
I tested the download on multiple machines, and in a couple of cases the
update was realllly slow to download and timed out. I'm putting it down
to the eclipse servers being really busy - maybe everyone is trying to get
AJDT at the same time ;)
Andy.
FUDForum. Page generated in 0.03403 seconds
