Home » Archived » BIRT » Does BIRT 2.2 support "named" parameters of data sets?
Does BIRT 2.2 support "named" parameters of data sets? [message #340267] Fri, 25 January 2008 10:17 Go to next message
I saw a few postings in the newsgroup about this with no direct answer. Is
there a way in BIRT 2.2 to use named parameters in data sets? The APIs and
the help pages imply it is doable, but when I tried to do it in my custom
ODA driver, the parameters are only bound by "position" and not "name" in
the query implementation. The only work around i could think of is to ask
the user to use a naming convention in naming the params (that include the
position) like "param1, param2...etc", which is ugly. If there is right way
to do this properly? If not, is it scheduled to be done in an upcoming
version of BIRT? I appreciate your help.
Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #345705 is a reply to message #340267] Mon, 28 January 2008 21:05 Go to previous message
Maged,
Support of "named" parameters defined by an ODA driver has been added since
BIRT 2.2.1.
See the comments in Bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122194#c7 on the specifics.
Linda
"Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
news:fncuj9$9dh$1@build.eclipse.org...
> Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #345780 is a reply to message #340267] Mon, 28 January 2008 21:05 Go to previous message
Maged,
BIRT 2.2.1.
Linda
> Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #349920 is a reply to message #340267] Mon, 28 January 2008 21:05 Go to previous message
Maged,
BIRT 2.2.1.
Linda
> Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #349995 is a reply to message #340267] Mon, 28 January 2008 21:05 Go to previous message
Maged,
BIRT 2.2.1.
Linda
> Maged
Previous Topic:Does BIRT 2.2 support "named" parameters of data sets?
Next Topic:Does BIRT 2.2 support "named" parameters of data sets?
Current Time: Mon Apr 28 02:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.04034 seconds
