Kura Use Case [message #1861482] |
Sun, 15 October 2023 18:26 |
Kevin Hanover Messages: 1 Registered: October 2023 |
Junior Member |
I'm currently working with a hotel company that has the following requirements:
Each hotel has an average of six 3rd party systems that need to communicate with the hotels cloud-based property management system. These systems use either RS232 or TCP/IP communications and have a high volume of messages going back and forth in real-time between the hotel PMS and the third-party systems, i.e., PBX, point of sale systems, housekeeping systems, credit card gateways, etc. I'm concerned about the Kura being able to run at least six OSGI bundles simultaneously, sometimes more for larger hotels i.e., ten to twelve, and not get overloaded. I know Kura can only handle ten inflight messages at a time and publishing too quickly can cause the datastore to overflow and throw an exception. Do you think Kura is a good option for this use case as the use case is not really an IOT type of system.
FUDForum. Page generated in 0.03002 seconds
