Renaming variable renamed in ALL files of the project [message #1832838] |
Sat, 26 September 2020 11:39 |
Jean-Yves Toumit Messages: 3 Registered: September 2020 |
Junior Member |
Hi all,
when renaming a variable in one php file, it renamed that variable to the new name in ALL php files of my project. That created of course a huge chaos in the project because of overlapping variable names in other files.
Thankfully, I had backups and didn't make too many changes today, so I could recover without too much hassle.
Is this really a desired behaviour? Especially as "Undo" would only work on the current file AND would not save it correctly later because it didn't detect the undo change. Basically, it killed 50% of my project files in one shot with no possible recovery!
I would assume that when renaming a variable, it would do so by sticking to the current file only (and probably actually only the current scope). Is this because the variable was actually assigned not within a block... although it was absolutely NOT a global variable?
I will be very wary in the future of renaming anything with this plugin. Once bitten, twice shy.
JY.
FUDForum. Page generated in 0.02886 seconds
