Re: Workbench layed out incompletely after restoring a view [message #337062 is a reply to message #337059] |
Sat, 25 July 2009 12:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David Wegener![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dpwegener%40gmail.com) Messages: 1445 Registered: July 2009 |
Felix Dorner wrote:
> Whenever I restore a minimized view, the workbench doesn't seem to
> complete to relayout its contents. It seems like the view gets its
> position, but the other components don't adapt to the new layout of the
> workbench. As part of another post I already hosted this screenshot,
> that shows the situation:
> http://img9.imageshack.us/img9/5183/screendqe.png
> If you look at the console view in the bottom, it's just painted over
> the editor, hiding for example the editors lower corners and its lower
> scroll bar button.
> I can fix the layout by dragging the afffected view around a bit.
> The described behaviour occurs whenever I restore *any* minimized view.
> Also happens in RCP apps.
> Some feeling tells me that this is OS specific. I am with Eclipse 3.5 on
> XUbuntu ( uses libgtk 2.16.1-0ubuntu2 )
> Should I report a bug?
> Felix
Minimized views behave similar to fast views. In the lower right hand
corner, you have icons for all views in the tab folder that was
minimized. If you select an individual view icon, only that view is
displayed. When displayed, it is displayed on top of the rest of the
workbench window. At the left end of the icons is the restore button.
This button returns the tab folder to its pre-minimized state and
incorporates it into the workbench window.
FUDForum. Page generated in 0.03301 seconds
