Home » Eclipse Projects » Eclipse Platform » How To Define A Startup Perspective For My Plugin
How To Define A Startup Perspective For My Plugin [message #337004] Mon, 20 July 2009 14:58 Go to next message
Originally posted by: runzhou.li.gmail.com
I want to have my own customized perspective to be launched together with my
plugin, how can this be done?
Thank you in advance :)
Runzhou Li
Re: How To Define A Startup Perspective For My Plugin [message #337007 is a reply to message #337004] Mon, 20 July 2009 16:03 Go to previous messageGo to next message
Runzhou Li wrote:
> Runzhou Li
Declare a perspectiv extension. If you create the RCP Mail application,
and look at the plugin.xml and the generated Perspective.java, you'll
see how it's done.
Then just call:
PlatformUI.getWorkbench().showPerspective(perspectiveId, window)
Felix
Re: How To Define A Startup Perspective For My Plugin [message #337008 is a reply to message #337007] Mon, 20 July 2009 17:09 Go to previous messageGo to next message
Thank you so much Felix, I'm going to try this out :)
"Felix Dorner" <felix_do@web.de> wrote in message
news:h42ii0$8ck$1@build.eclipse.org...
> Runzhou Li wrote:
>> my plugin, how can this be done?
>> Runzhou Li
> and look at the plugin.xml and the generated Perspective.java, you'll see
> how it's done.
> Then just call:
> Felix
Re: How To Define A Startup Perspective For My Plugin [message #337020 is a reply to message #337007] Tue, 21 July 2009 12:05 Go to previous message
Unfortunately it failed to do so if the perspective is not opened
previously, i.e. if I only have J2EE perspective opened and wish to use
PlatformUI.getWorkbench().showPerspective(perspectiveId, window) to show
Java perspective, then it fails; only if I have both perspectives opened but
the Java is not activated could allow me to use this method to switch the
focus to Java perspective.
Please help :)
> Runzhou Li wrote:
>> Runzhou Li
> how it's done.
> Then just call:
> Felix
Previous Topic:IMarker for org.eclipse.swt.widgets.Table
Next Topic:Mac OS + Galileo
Current Time: Sat Nov 01 18:07:46 EDT 2025
Powered by FUDForum. Page generated in 0.03359 seconds
