Home » Eclipse Projects » Eclipse Platform » usage of dropAssistant for org.eclipse.ui.navigator.navigatorContent
usage of dropAssistant for org.eclipse.ui.navigator.navigatorContent [message #336996] Mon, 20 July 2009 09:03 Go to next message
The org.eclipse.ui.navigator.navigatorContent can have a drop assistant
however it is only triggered when attempting to drop something
corresponding to possibleChildren. I want to be able to slurp a file and
import everything from it into the database represented by on tree
element. That tree element will not get a file as a children after this
operation. In fact my database element will NEVER EVER have files as
children. So it feels very wrong to add that as a possibleChildren. Is
that what I am supposed to do anyway? What other strange effects will that
have? I don't want my tree to be able to contain files in some strange
corner case...
Re: usage of dropAssistant for org.eclipse.ui.navigator.navigatorContent [message #486792 is a reply to message #336996] Sat, 19 September 2009 00:54 Go to previous message
Jonathan wrote on Mon, 20 July 2009 09:03
corner case...
Don't get too hung up on the name possibleChildren. This is what triggers the drop assistant, so that's the property way to do it. If there are no actual children provided, then there will be no side effects.
Previous Topic:Common Navigator fails to refresh on addition/deletion
Next Topic:Referenced class not on plugin classpath
Current Time: Mon Oct 27 18:05:40 EDT 2025
Powered by FUDForum. Page generated in 0.05137 seconds
