Other views [message #336866] |
Wed, 08 July 2009 15:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Why does Eclipse collect our plugin's Views under the Other category
under Window | Show Views?
Re: Other views [message #336873 is a reply to message #336868] |
Wed, 08 July 2009 17:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On Wed, 08 Jul 2009 22:17:28 +0530, Prakash G.R. wrote:
> Dilton McGowan II wrote:
> Because your views are not in the current perspectives view
shortcuts.
> If you own the perspective call IPageLayout.addShowViewShortcut(), else
> contribute thru the extension point org.eclipse.ui.perspectiveExtensions
> - Prakash
> http://blog.eclipse-tips.com
I'll look more into those things, thanks Prakash.
Re: Other views [message #336937 is a reply to message #336868] |
Tue, 14 July 2009 20:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
shortcuts.
> - Prakash
It turns out that I had not added a Category under Extension Element
Details for my org.eclipse.ui.views extension. Once I did this and
assigned my views to that category, they are now showing where I'd expect
in the Show View dialog.
FUDForum. Page generated in 0.03297 seconds
