Re: Galileo problems? [message #336820 is a reply to message #336817] |
Sun, 05 July 2009 17:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dan Thurman![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dant%40cdkkt.com) Messages: 57 Registered: July 2009 |
Member |
On Sat, 04 Jul 2009 21:29:43 +0000, Dan Thurman wrote:
> I have encountered some problems with Galileo:
> 1) Galileo does not save selected perspectives
> in the toolbar when exiting and thus starting eclipse only displays
> JavaEE. Note, I usually have my perspectives toolbar docked on the
> left side.
> 2) Somehow, I have lost on startup, the option
> to select my workspace.
Due to this step failing to prompt users for
workspace on startup, it continues on with the
last saved workspace regardless if the workspace
path is preference saved or completely removed of
which I erroneously reported (1) above as an error.
I had assumed I was working with the last saved
workspace on shutdown and this mechanism failed.
So - there is a problem specifically with the
Startup/Shutdown handler in regards to the
workspace switcher, or so it seems.
> Where can I reactivate this default setting?
Never mind this request, I found it in:
Windows->Preferences->General->Startup and Shutdown->Workspaces
New Additions:
Subversion under Galileo does not work cleanly
as it works fine under Ganamede.
1) Galileo Svn does not correctly show trunk trees
(it shows only subsets of projects).
2) Galileo Svn has severe problems in saving projects
as it results in a corrupted repository, directory,
or files and incorrectly displays results and errors.
3) Galileo Svn has problems with authentication whereas
this is not a problem under Ganamede.
> I could not locate a newsgroup that is specific to the Galileo release,
> so I am not sure this is the correct newsgroup to which to post this
> message.
> Thanks!
> Dan
FUDForum. Page generated in 0.03736 seconds
