| I found a bug, not sure what todo [message #336740] | Tue, 30 June 2009 04:10  |  |
| Eclipse User  |  |  |  |  | Hi, I've found a very little bug, but I don't know what to do.
 Since I'm new to plugin development, I'm not 100% sure that it is a bug or
 I've done an error, and I don't want to mae an Eclipse developer waste his
 time because I reported a fake error.
 Everithing that is foolowing in this post is in my VERY HUMBLE opinion
 The error is in the class
 org.eclipse.ui.texteditor.AbstractDecoratedTextEditor and affect the
 method gotoMarker(IMarker);
 (next to last row of method ):
 if (end - 1 < length && start < length)
 The error IMHO is that '-1'. I've found that the goto works if start==end
 (this means that it is a simple move of the caret, while start!=end means
 a goto+text selection
 However, the -1 prevents the goto to go to the end of the file (I needed
 in my plugin to open an editor at the end of a file so the user can start
 appending text without any other keystroke)
 Should I post a bug to bugzilla, or even put a patch? Is there any
 official reference about eclipse contributing, may you provide link?
 thanks
 Alex
| Re: I found a bug, not sure what todo [message #336741 is a reply to message #336740] | Tue, 30 June 2009 04:41   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------020807090407030600010107
 Alex,
 It sounds like a bug to be able to move anywhere except past the last
 character.  Your description is simple enough that a bugzilla with this
 information should be sufficient.  Because the fix is also trivial, a
 patch shouldn't make a significant difference.  The getting involved
 link on this page doesn't provide much help
 http://www.eclipse.org/users/
 Perhaps there's a better one, but it's not easy to find...
 > bug or I've done an error, and I don't want to mae an Eclipse
 > developer waste his time because I reported a fake error.
 > start==end (this means that it is a simple move of the caret, while
 > start!=end means a goto+text selection
 > needed in my plugin to open an editor at the end of a file so the user
 > can start appending text without any other keystroke)
 > thanks
 > Alex
 <html>
 <head>
 http-equiv="Content-Type">
 </head>
 Alex,<br>
 <br>
 character.
FUDForum. Page generated in 0.72130 seconds
