Galileo Release - ClearCase-Plugin is not correct [message #336624] |
Thu, 25 June 2009 09:57  |
Hi there,
please let me know if this is not the proper ng for this topic.
We use ClearCase for SCM with the plugin from [1]. This plugin works
nice with RC3 and RC4 of Galileo. But now with the released version of
Galileo it doesn't work correct. On the list of installed plugins it is
shown and I can't find any error. But it is not visible on the GUI which
means that there is no toolbar and even the context menu "Team" has only
the two default entries.
Strange is, that it seems to work. So I can see the underlays under the
icons in front of the files on a project, which tells that this file is
under source control or not. Additionally the name of the ClearCase-View
is displayed correctly. This tells me that the connection to ClearCase
is successfully done.
If an opened file is edited, the ClearCase checkout dialog pops up and
the proper symbol for a checked out file appears on the icon of this
file. But with an empty Team context menu and no toolbar I can't checkin
the files or do all the other neccessary stuff like version tree, merge
and so on.
Any suggestions? Should I file a bug report?
[1]
http://www.ibm.com/developerworks/rational/library/content/0 3July/2500/2834/ClearCase/clearcase_plugins.html#download
Yves
Re: Galileo Release - ClearCase-Plugin is not correct [message #336629 is a reply to message #336627] |
Thu, 25 June 2009 10:43  |
Hi Dave
Dave Wegener schrieb:
> Which version are you using?
We use the version from the website from [1] which is
"com.rational.clearcase.win32-20081031A.zip". Is there a newer version
somewhere else?
> If it is the latest 7.0.0 version for 3.4, make sure that you follow the
> directions for Activating the ClearCase SCM Adapter in the Tasks section of
> the Rational ClearCase SCM Adapter help document. You need to use the
> Eclipse Capabilities feature to active the latest version.
You made my day! That's it, thank you very much. <thumbs-up/>
Yves
"Hamburger! Der Grundstein eines jeden nahrhaften Frühstücks!" -- Pulp
Fiction
FUDForum. Page generated in 0.05600 seconds
