Home » Eclipse Projects » Eclipse Platform » Documentation on Command's handlers (Using commands in cheatsheets).
Documentation on Command's handlers (Using commands in cheatsheets). [message #336578] Wed, 24 June 2009 09:29 Go to next message
Hi everybody.
I'm trying to make a cheat sheet where the results of one/some steps are
used as inputs in others.
I'm having trouble finding the associated handlers for some commands in
order to figure out if those handlers return anything.
In particular, I'm trying to use
org.eclipse.ui.newWizard(newWizardId=org.eclipse.uml2.uml.ed itor.presentation.UMLModelWizardID)
org.eclipse.ui.file.import(importWizardId=org.eclipse.ui.wiz ards.import.FileSystem)
to name a few.
I wanted to know if: A) The "new UML Model" wizard command returns a
reference to the generated UML model (or its path, o smthg),
B) If the "Import File System" wizard
command returns a reference to the imported element.
Where is the correct place to look for such documentation?
(command<->handler correspondences or documentation on the command
(input parameters, returned objects, etc.)).
Juan Pedro
Re: Documentation on Command's handlers (Using commands in cheatsheets). [message #336602 is a reply to message #336578] Wed, 24 June 2009 16:54 Go to previous messageGo to next message
Juan Pedro Silva wrote:
> Hi everybody.
If commands return a parameter, then it should be identified in the
command definition (which you can see in the Plug-in Registry view). It
would include a returnTypeId which points to the commandParameterType
that the command can return.
AFAIK the default handlers for import
org.eclipse.ui.internal.handlers.WizardHandler.Import and new wizard
org.eclipse.ui.internal.handlers.WizardHandler.New don't return anything.
Paul Webster
Re: Documentation on Command's handlers (Using commands in cheatsheets). [message #336614 is a reply to message #336602] Thu, 25 June 2009 04:41 Go to previous messageGo to next message
Thank you Paul for your answer..
Which way would you suggest to go to feed the resulting imported
file/new file into the next step in the cheatsheet?.
As you said, those commands don't return anything, so I can't use
neither parameters nor variables.
Is suggesting the user to select the file in the project explorer before
running the command and using "active selection" the correct way to go?.
Juan Pedro
>> Hi everybody.
>> are used as inputs in others.
>> in order to figure out if those handlers return anything.
> It would include a returnTypeId which points to the
> commandParameterType that the command can return.
Re: Documentation on Command's handlers (Using commands in cheatsheets). [message #336659 is a reply to message #336614] Fri, 26 June 2009 10:15 Go to previous message
if they then select the new file in the explorer you could use the
"selection", or if creating the new file opened the editor you could use
the editor input of the activeEditor
PW
Paul Webster
Previous Topic:Problem with Eclipse ANT integration
Next Topic:Eclipse 3.5M6 Update behind proxy not working anymore
Current Time: Wed Oct 29 19:13:14 EDT 2025
Powered by FUDForum. Page generated in 0.03064 seconds
