Re: Galileo - "dropins" folder not working? [message #336580 is a reply to message #336575] |
Wed, 24 June 2009 14:46 |
Originally posted by: phillipus.nowhere.net
Ed Merks wrote:
> Phillipus,
> I'd try running with -clean -debug and looking carefully at what's in
> the Error log. The -debug flag will produce more detailed messages
> about why something might fail to activate, i.e., unsatisfied range
> constraints on bundle dependencies...
> Phillipus wrote:
>> Just got Eclipse 3.5. Put all my plug-ins in the "dropins" folder and
>> they don't show up. No way no how.
>> Am I missing something?
Ed, I found out what it is. It's an issue with installing the Delta pack.
On Windows:
1. Install a clean Eclipse 3.5
2. Unzip the Delta pack over it.
3. Put some plug-ins in the dropins folder
Result - they don't show up in Eclipse.
Don't install the Delta pack and it's fine.
I'm sure we had this bug in an earlier version of Eclipse.
Phillipus
Re: Galileo - "dropins" folder not working? [message #336581 is a reply to message #336580] |
Wed, 24 June 2009 14:51 |
Phillipus wrote:
> Ed Merks wrote:
>> Phillipus,
> On Windows:
> Phillipus
Bugbased - https://bugs.eclipse.org/bugs/show_bug.cgi?id=281353
Re: Galileo - "dropins" folder not working? [message #336583 is a reply to message #336581] |
Wed, 24 June 2009 15:06 |
Phillipus wrote:
> Phillipus wrote:
>> Ed Merks wrote:
>>> Phillipus,
>>>> and they don't show up. No way no how.
>> On Windows:
>> Phillipus
In fact, things are worse than that - installing the Delta pack means
that no new plug-ins show up at all, even if they are in the normal
"plugins" folder!
Re: Galileo - "dropins" folder not working? [message #336584 is a reply to message #336583] |
Wed, 24 June 2009 15:15 |
Phillipus wrote:
> Phillipus wrote:
>> Phillipus wrote:
>>> Ed Merks wrote:
>>>> Phillipus,
>>>> in the Error log. The -debug flag will produce more detailed
>>>> messages about why something might fail to activate, i.e.,
>>>> unsatisfied range constraints on bundle dependencies...
>>> pack.
>>> On Windows:
>>> Phillipus
> "plugins" folder!
Er, even worser....The Delta pack doesn't show up at all, I think it's
screwed. That kind of means no RCP development in 3.5. Ho hum.
Re: Galileo - "dropins" folder not working? [message #336585 is a reply to message #336584] |
Wed, 24 June 2009 15:19 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Why are you installing the delta pack into your eclipse installation?
You should create your own target and point PDE to it instead of using
the running Eclipse-Instance as the target.
Tom
Phillipus schrieb:
> Phillipus wrote:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Ed Merks wrote:
>>>>> Phillipus,
>>>> pack.
>>>> On Windows:
>>>> Phillipus
>> "plugins" folder!
Re: Galileo - "dropins" folder not working? [message #336586 is a reply to message #336585] |
Wed, 24 June 2009 15:30 |
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Why? Because that's what I've always done. Target is the same as host.
That's what it's intended for. That's why it's a Delta pack.
Re: Galileo - "dropins" folder not working? [message #336588 is a reply to message #336585] |
Wed, 24 June 2009 15:39 |
Tom Schindl wrote:
> Tom
> Phillipus schrieb:
>> Phillipus wrote:
>>> Phillipus wrote:
>>>> Phillipus wrote:
>>>>> Ed Merks wrote:
>>>>>> Phillipus,
>>>>> pack.
>>>>> On Windows:
>>>>> Phillipus
>>> "plugins" folder!
Mind you, doing that fixes the problem. Perhaps in 3.5 the Delta pack is
not meant to be installed over the running installation.
Re: Galileo - "dropins" folder not working? [message #336595 is a reply to message #336593] |
Wed, 24 June 2009 17:27 |
>>>>> "plugins" folder!
>> is not meant to be installed over the running installation.
> This will likely have to do with problems generating metadata on the
> org.eclipse.equinox.executable feature. See bug
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=248578
> The best way to install the delta pack is to extract it to its own
> directory and then add it to your target platform by editing the Active
> Target and adding the deltapack/eclipse directory.
Thanks for the info!
FUDForum. Page generated in 0.05679 seconds
