Re: Open Diagram with Errors [message #336558 is a reply to message #336557] |
Tue, 23 June 2009 08:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33180 Registered: July 2009 |
Gilod,
It's best to ask on the GMF newsgroup, so I've added it to the "to" list
of my reply.
I don't think anyone will be able to help unless you provide at least a
stack trace related to the problem. You should be able to find that in
the Error log view.
Gilod wrote:
> Hello
> I have a presentation tomorrow where in I show my validation ability
> that run on a diagram I created using EMF and OCL audit rules in the
> gmfmap file.
> When I run the validate button, its shows the errors/ warning as needed.
> But, when I close the diagram (which has errors/ warning) and try to
> re-open it - it get stack and so the whole application...
> If I solve the errors before closing the diagram,
> Its re-open with no problem.
> I thought is might be something with the syncronization, but I refresh
> the project each time there is some modification and it still doesn't
> help.
> When there is a diagram file with an Error/ Warning icon - it does not
> open.
> Can you please advice??
> Thanks
> Gilod
Ed Merks
FUDForum. Page generated in 0.02676 seconds
