Re: UTF-8 Encoding [message #336540 is a reply to message #336539] |
Mon, 22 June 2009 06:16 |
Originally posted by: subs._nospam_consertum.com
Sheela wrote:
> My eclipse based IDE involves reading XML's as metadata. These XML's
> could contain special characters. However i ve noticed that eclipse's
> default encoding is set to "Cp1252".
> If i change my eclipse workspaces' encoding to UTF-8, and then export my
> product, it seems to work fine. However I would rather code it in my
> product so that i dont have to change the workspace settings. Is there a
> way to set the default encoding to UTF-8 in the code?
> Thanks in Advance,
> Sheela
You can put the following entry into your plugin_customization.ini:
org.eclipse.core.resources/encoding=UTF-8
Derek
FUDForum. Page generated in 0.03462 seconds
