Re: How to build and wait IProject.build()? [message #336534 is a reply to message #336529] |
Sat, 20 June 2009 09:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33179 Registered: July 2009 |
Richard,
There was a bug in one of the older Galileo drivers where the build
didn't complete by the time the call to build return, but that should be
fixed now. Which version of Eclipse are you using?
Richard O. Legendi wrote:
> Hi!
> I have an IJavaProject and I would like to build it and wait for the
> compiler to generate the necessary class files. I have tried the
> following solution:
> final IProgressMonitor monitor = new IProgressMonitor() {
> boolean isDone = false;
> @Override
> public void done() {
> if (!isDone) {
> isDone = true;
> // doing the post-compilation stuff here
> project.build( IncrementalProjectBuilder.INCREMENTAL_BUILD, monitor );
> My problem is that in some cases done() is called several times. Ok,
> I've introduced that isDone flag, and the handler code is executed
> only after the first call (hope it's right this way).
> However, it seems the class files I require are not exists when done()
> is called. What am I doing wrong? Any suggestions how to deal with this?
> Checking how many times done() is called and executing the code then
> would obviously a nightmare, and ain't sure if it would even work.
> (I want to compile the java files in the project and put them into a
> jar. However, some of the class files are always missing or they are
> partially compiled in the generated jar).
> Thanks in advance,
> Richard O. Legendi, programmer
> AITIA International Inc.
> E-mail: rlegendi@aitia.ai
Ed Merks
Re: How to build and wait IProject.build()? [message #336542 is a reply to message #336534] |
Mon, 22 June 2009 06:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Richard Oliver Legendi![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=rlegendi%40aitia.ai) Messages: 34 Registered: July 2009 |
Member |
Hi Ed!
Thanks for the reply. I'm using this build of Eclipse:
Version: 3.4.2
Build id: M20090211-1700
I guess it's a new version so I'll search the Bugzilla for this issue, thanks
for pointing it out.
Richard
Ed Merks wrote:
> Richard,
>> Hi!
>> following solution:
>> @Override
>> if (!isDone) {
>> isDone = true;
>> Thanks in advance,
FUDForum. Page generated in 0.02966 seconds
