Re: Team API Commit event [message #336514 is a reply to message #336495] |
Thu, 18 June 2009 13:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Michael Valenta![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipsemfv%40gmail.com) Messages: 35 Registered: July 2009 |
Member |
In that case, I would suggest you search through bugzilla in the Eclipse
Team component. This question has been asked before so I'm sure there
are several bugs related to the topic. You can add yourself to the CC of
the bugs and state your requirements there.
Michael
Yaron Burg wrote:
> Hi Michael,
> Thanks for your answer.
> SCMBUG sounds interesting and I'll take a close look into it.
> However, I'm not sure it can do everything I want.
> The plugin I'm working on is a task repository connector for Mylyn and
> I'm trying to create the link between change set and defect, as part of
> this project.
> Yaron.
> Michael Valenta wrote:
>> Yaron,
>> Whether or not there is a Team API available is really just a
>> convenience. The real questions is whether SCM system X has a callback
>> hook during a commit that would allow you to do what you want. The
>> answer for most system is yes but the hooks are server-side and not on
>> the client since this is the only way to guarantee that the hook gets
>> run for every commit. You may want to have a look at SCMBUG
>> (http://freshmeat.net/projects/scmbug/) as it provides a common
>> interface between SCM systems and bug reporting systems for doing
>> something similar to what you are asking for.
>> Michael
>> Yaron Burg wrote:
>>> Hi everyone,
>>> Hope this is the right place for such questions. if not, can you
>>> point me the the right location?
>>> I'm looking for a way to capture the commit event when checking in
>>> files to any CM system. is it possible? will it be possible in the
>>> future? has anyone done it before?
>>> The scenario is:
>>> The user commits the files
>>> after a successful commit action, I get the list of checked-in files
>>> with revision number and write it to another system.
>>> I would like to use a high level API in order to make it CM vendor
>>> independent.
>>> So far all I found are answers like "it's not possible"...
>>> how about AspectJ? can it help?
>>> Thanks for your help!
>>> Yaron.
FUDForum. Page generated in 0.03142 seconds
