Home » Eclipse Projects » Eclipse Platform » slow multi-user startup of eclipse
slow multi-user startup of eclipse [message #336404] Wed, 10 June 2009 04:17
Originally posted by: dave.nospam.com
I'm running Eclipse (Ganymede) in a multi-user environment and it is
always very slow when a user starts up Eclipse for the first time. I
have installed and initialized Eclipse as root and made the
configuration directory read-only so believe it should be a shared
install. Have I missed something?
When a user starts Eclipse for the first time it takes some time while
several plugins are copied into the user's home .eclipse directory. Does
this suggest the shared install has failed? Is it a feature of Eclipse
that the initial startup is much slower even in a shared install
configuration?
Any help or links to help on this topic appreciated (I've already found
the Eclipse multi-user installs instructions).
Dave
Previous Topic:[CommonNavigator] Handling Global 'Open' to open an Editor
Next Topic:Viewing Source from Maven Repository
Current Time: Fri Apr 25 00:30:20 EDT 2025
Powered by FUDForum. Page generated in 0.03433 seconds
