Home » Eclipse Projects » Eclipse Platform » JFace Viewer
JFace Viewer [message #336259] Wed, 03 June 2009 22:48 Go to next message
Is there any way I can stop my TreeViewer from completely collapsing on
a setInput()?
Re: JFace Viewer [message #336260 is a reply to message #336259] Thu, 04 June 2009 01:26 Go to previous messageGo to next message
> a setInput()?
I think that its not a good idea for TreeViewer to expand all when
setting the input. It would have severe performance impact if the tree
depth is more or if fetching of each element is time consuming.
However, if you really need to do that for your app, you can call
treeViewer.expandAll() or treeViewer.expandToLevel() methods
- Prakash
http://blog.eclipse-tips.com
Re: JFace Viewer [message #336277 is a reply to message #336260] Thu, 04 June 2009 18:54 Go to previous messageGo to next message
Originally posted by: wim.jongman.gmail.com
Hi Andy,
Alternatively you can get the current expanded nodes before setinput and
expand exactly that after setinput. Stop the tree from drawing in between and
show a nice progress dialog if it takes longer.
Best Regards,
Wim Jongman
>> a setInput()?
> - Prakash
Re: JFace Viewer [message #336454 is a reply to message #336259] Sat, 13 June 2009 00:19 Go to previous messageGo to next message
> a setInput()?
In order to stop this from happening your domain objects that are being
displayed in the TreeView have to correctly implement compareTo, equals
and HasCode. Once you have done this it should stop happening.
An additional thing I do is that after I add an item to the list backing
the tree viewer I create a TreeSelection object and call the
setSelection method on the TreeViewer passing it the selection object,
If the TreeSelection object is created correctly the item you just added
should be the selected item in the tree with the branch it is in expanded.
Hope this helps, good luck.
Re: JFace Viewer [message #336455 is a reply to message #336454] Sat, 13 June 2009 03:35 Go to previous messageGo to next message
As an alternative you can also set an IElementComparer on the viewer.
Tom
>> on a setInput()?
Re: JFace Viewer [message #336471 is a reply to message #336455] Mon, 15 June 2009 21:50 Go to previous message
Interesting information on the domain objects needing to be Comparable.
That accents a behavior change I noted in my TreeViewer when I changed my
top level object to implement Comparable and overrode compareTo().
For not collapsing the TreeViewer on setInput(), however, would it be Ok
if it reset to a default expand level? I believe setAutoExpandLevel()
will do that for you...
Previous Topic:Workspace ADDED distinguished from file system ADDED
Next Topic:Was "Delete project contents on disk (cannot be undone)" selected
Current Time: Tue Oct 14 00:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.05794 seconds
