Home » Eclipse Projects » Eclipse Platform » Starting eclipse with Java in the same JVM
Starting eclipse with Java in the same JVM [message #336218] Fri, 29 May 2009 20:41 Go to next message
Markus Oley is currently offline Markus OleyFriend
Hi everyone,
I want to start an SWTBot Test with Ant, so I have to start an
eclipse-instance in the same JVM as the Test runs.
In which I can do this?
Tanks in advance
Re: Starting eclipse with Java in the same JVM [message #336225 is a reply to message #336218] Mon, 01 June 2009 13:29 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Starting Eclipse from Java
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/misc/eclipsestarter.html
Paul Webster
Previous Topic:space value in plugin.xml
Next Topic:Common Navigator Framework and drag out to Windows
Current Time: Wed Jul 17 01:37:32 GMT 2024
Powered by FUDForum. Page generated in 0.03072 seconds
