Home » Eclipse Projects » Eclipse Platform » BasicNewFileResourceWizard
BasicNewFileResourceWizard [message #336178] |
Wed, 27 May 2009 18:43  |
Originally posted by: riwright.adobe.com
I am building a custom perspective to support some scientific modeling. As
part of the workflow, I need to let the user create new datasets (which are
arrays in memory, zipfiles on disk). There are several aspects to datasets,
including class-type, dataset type, name, number of dimensions, elements per
dimensions, etc.
This sort of calls out for a wizard and it seems like a subclass of
BasicNewFileResourceWizard would be the way to go. But the documentation
says "This class can be instantiated, but is not intended to be
sub-classed". Why? How should this be done in a blessed way? I hate to
re-invent the wheel by building out a wizard that already exists.
TIA, Ric
Re: BasicNewFileResourceWizard [message #336184 is a reply to message #336178] |
Thu, 28 May 2009 06:45   |
--------------070200080606090603040901
Ric,
It sounds like maybe you should be using EMF
<http://www.eclipse.org/modeling/emf/?project=emf>. :-P
If you did, EMF would generate exactly the kind of wizard you'd need to
do what you describe. You should be extending Wizard and reusing the
WizardNewFileCreationPage.
If you follow one of the tutorials, it will generate an example:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
> dimensions, etc.
> TIA, Ric
<html>
<head>
</head>
Ric,<br>
<br>
It sounds like maybe you should be using <a
href="http://www.eclipse.org/modeling/emf/?project=emf">EMF</a>. :-P<br>
<br>
WizardNewFileCreationPage.<br>
<br>
If you follow one of the tutorials, it will generate an example: <br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
<br>
Ric Wright wrote:
<blockquote cite="mid:C6431032.2A1E3%25riwright@adobe.com" type="cite">
<pre wrap="">I am building a custom perspective to support some scientific modeling. As
dimensions, etc.
TIA, Ric
</pre>
</blockquote>
</body>
</html>
--------------070200080606090603040901--
Re: BasicNewFileResourceWizard [message #336215 is a reply to message #336195] |
Fri, 29 May 2009 15:15  |
Ric Wright wrote:
> Ed,
> Thanks for the pointer to the tutorial. Very detailed. I’ll walk
> through it, but it seems like overkill for what I need. But I will walk
> through it and see how it goes. I think pieces of it are appropriate
> and maybe I can apply parts of it.
The parts that are key, as Ed mentioned, are to extend
org.eclipse.jface.wizard.Wizard and in the addPages() method call
addPage(IWizardPage) for each page you want to create.
This package has a couple of useful base class that you can look at as
examples for your Wizard and WizardPage implementations (note, these are
GPL licensed code):
https://www.skywayperspectives.org/fisheye/browse/CVS_OpenSo urce/skyway/common/plugins/org.skyway.ui/src/org/skyway/ui/w izard
Hope this helps,
Eric
> On 5/28/09 3:45 AM, in article gvlq09$l49$1@build.eclipse.org, "Ed
> Merks" <Ed.Merks@gmail.com> wrote:
> Ric,
> <http://www.eclipse.org/modeling/emf/?project=emf> . :-P
> to do what you describe. You should be extending Wizard and reusing
> the WizardNewFileCreationPage.
> modeling. As
> (which are
> to datasets,
> elements per
> dimensions, etc.
> documentation
> I hate to
> TIA, Ric
Current Time: Sun Apr 27 03:12:32 EDT 2025
Powered by FUDForum. Page generated in 0.05151 seconds
