Home » Eclipse Projects » Eclipse Platform » Find fields with SearchEngine
Find fields with SearchEngine [message #336149] Tue, 26 May 2009 16:25 Go to next message
Hello
My problem concerns the results of the SearchEngine used in a plugin
implementing CompletionAssist in javaEditor. My goal is obtain all fields
in a method. The following code permits to get all member class fields but
not the fields declared in the method. Is-it possible to do? What's failed
in my code ?
IWorkbenchPage page=PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getActivePage();
IJavaElement element= JavaUI.getEditorInputJavaElement(
page.getActiveEditor().getEditorInput());
IJavaSearchScope scope = SearchEngine.createJavaSearchScope(
new IJavaElement[] { element } ,true);
IEditorPart editor = page.getActiveEditor();
IFile file = ((IFileEditorInput) editor.getEditorInput()).getFile();
IJavaProject project = JavaCore.create(file.getProject());
SearchPattern searchPattern = SearchPattern.createPattern(
IJavaSearchConstants.FIELD,
IJavaSearchConstants.DECLARATIONS,
SearchPattern.R_PATTERN_MATCH);
final List<Object> list = new ArrayList<Object>();
SearchRequestor requestor = new SearchRequestor() {
public void acceptSearchMatch(SearchMatch match) {
Object element = match.getElement();
list.add((Object)element);
if (element instanceof IJavaElement) {
logger.debug("element is IJavaElement");
IJavaElement e = (IJavaElement)element;
logger.debug(e.getAdapter(IJavaElement.class));
logger.debug(e.getClass());
SearchEngine searchEngine = new SearchEngine();
try {
searchEngine.search(searchPattern,
new SearchParticipant[] {
SearchEngine.getDefaultSearchParticipant()},
scope,
requestor,
new NullProgressMonitor());
} catch (CoreException e) {
logger.debug(e.getMessage());
So, editing the following sample class :
public class cc {
private Object1 obj1= null;
private Object2 obj2= null;
* Main
new cc();
* Constructor
public cc() {
try {
Object3 obj3 = new Object3();
// Fills input datas
obj3.get <---------------- completion
... when I ask completion, my code is executed but only obj1 and obj2 are
found... not obj3 in constructor...
Thanks for your help
Re: Find fields with SearchEngine [message #336188 is a reply to message #336149] Thu, 28 May 2009 08:51 Go to previous messageGo to next message
michel wrote:
> Hello
> fields in a method. The following code permits to get all member class
> fields but not the fields declared in the method.
Fields cannot be declared inside a method.
Dani
> Is-it possible to do? What's failed in my code ?
> IWorkbenchPage
> .getActivePage();
> try {
> searchEngine.search(searchPattern, new
> scope, requestor,
> public class cc {
> * Main
> public static void main(String[] args) {
> new cc();
> * Constructor
> public cc() {
> try {
> are found... not obj3 in constructor...
Re: Find fields with SearchEngine [message #336211 is a reply to message #336188] Fri, 29 May 2009 10:47 Go to previous messageGo to next message
Thank you
Concerning the method to find the class of the object declared in the
method (obj3) what is the best method to to that ?
I have tried the codeSelect(offset, length) method on the compilation unit
(offset points to the 'o' of obj3, for a length of 4) but have no result.
But perhaps I have not understood any thing in the mecanism ...
Re: Find fields with SearchEngine [message #336212 is a reply to message #336211] Fri, 29 May 2009 13:34 Go to previous message
Using AST (ASTVisitor) I have get a list of all components in the source.
I have always a problem.
It seems that ASTNodes relating all variables (or block, or try) in a
method A that contains an error doesn't pass in ASTVisitor methods. It is
very problematic during completion cause the target line is always in
error.
If I do completion in another method B, then the previous method A shows
all ASTNodes.
Is a solution exists ?
Thank you very much
Previous Topic:Setting up Bundle-RequiredExecutionEnvironment causes access restriction errors
Next Topic:Syntax Coloring for a Non-File based Editor
Current Time: Sun Oct 19 14:40:18 EDT 2025
Powered by FUDForum. Page generated in 0.58956 seconds
