| Syntax Coloring for a Non-File based Editor [message #336137] | Tue, 26 May 2009 03:30  |  |
| Eclipse User  |  |  |  |  | Originally posted by: pajai.extrabright.com
 Hi everybody,
 I am trying to get the syntax coloring working when setting an editor's
 content programmatically (for an existing editor, e.g. the Java one),
 but I have not come to a solution until now. I am not able to set the
 content type programmatically. The syntax coloring appears to work only
 when opening a file which extension is defined in the
 org.eclipse.ui.editors extension point.
 What I am doing until now:
 - define MyEditorInput extending IEditorInput
 - define MyDocumentProvider extending AbstractDocumentProvider and
 override createDocument, where I return a Document with the content I
 want if getting a parameter of type MyEditorInput. (I tried to override
 the method getContentType(Object), but it is never called.)
 - Open the Java editor programmatically with my custom input.
 Anyone has an idea what I should do for the syntax coloring to work or
 how I can set the content type programmatically?
 Thanks in advance.
 Patrick
| Re: Syntax Coloring for a Non-File based Editor [message #336213 is a reply to message #336137] | Fri, 29 May 2009 14:13  |  |
| Eclipse User  |  |  |  |  | Patrick J. wrote: > Hi everybody,
 Have you tried implementing IStorageEditorInput and *not* overriding
 the document provider?
 Nitin Dahyabhai
 Eclipse WTP Source Editing
 IBM Rational
FUDForum. Page generated in 0.06206 seconds
