Home » Eclipse Projects » Eclipse Platform » How to disable Plugin in Eclipse 3.4.2
How to disable Plugin in Eclipse 3.4.2 [message #336096] Thu, 21 May 2009 02:16 Go to next message
Hello.
How do I disable a plugin without uninstalling it?
In earlier versions of Eclipse there was Help->Software Updates->Manage
Configuration ; but it disappeared. On a side note: i don't think removing
menu items is such a good idea.
TIA
Re: How to disable Plugin in Eclipse 3.4.2 [message #336103 is a reply to message #336096] Thu, 21 May 2009 09:23 Go to previous messageGo to next message
In 3.4.x you can get to the same functionality using Help>Software
updates (it brings up a dialog that can manage the config as well).
PW
Paul Webster
Re: How to disable Plugin in Eclipse 3.4.2 [message #336110 is a reply to message #336103] Thu, 21 May 2009 13:35 Go to previous message
There does not seem to be a "disable" option. Only "uninstall". Why such a
functionality "regression" ?
Previous Topic:reverse/undo dirty state in an editor?
Next Topic:Re: Making View Visible After Mouse Click
Current Time: Thu Mar 06 09:13:59 EST 2025
Powered by FUDForum. Page generated in 0.03536 seconds
