Home » Eclipse Projects » Eclipse Platform » Auto close of editor area when last editor closed
Auto close of editor area when last editor closed [message #336055] Fri, 15 May 2009 14:51 Go to next message
My perspective has an editor area that initially is not visible (ie.
layout.setEditorAreaVisible(false)). When an edit occurs the editor area
becomes visible. When all editors are closed the editor area stays
visible and blank.
Is there a way to make the editor area not visible again once all editors
are closed?
Re: Auto close of editor area when last editor closed [message #336085 is a reply to message #336055] Wed, 20 May 2009 13:38 Go to previous message
There is an action, org.eclipse.ui.actions.ActionFactory.SHOW_EDITOR and
a command id = org.eclipse.ui.window.hideShowEditors
There is also (apparently) API on
org.eclipse.ui.IWorkbenchPage.setEditorAreaVisible(boolean)
PW
Paul Webster
Previous Topic:popup menu RCP eclipse 3.4
Next Topic:Access handler reference
Current Time: Mon Apr 28 05:04:58 EDT 2025
Powered by FUDForum. Page generated in 0.02600 seconds
