Editor has no focus after "Open Resource" [message #336027] |
Thu, 14 May 2009 08:43 |
Sebastian Beigel Messages: 6 Registered: July 2009 |
Junior Member |
using Eclipse 3.5 M7 (Java EE package, cocoa-build on Mac OS 10.5.7, clean
install, new workspace) I've noticed a bug using the "Open Resource"
dialog. After selecting a file, the according editor opens and the file
content is shown but the editor pane has no focus. The first line is
highlighted but the cursor/caret is invisible and the editor receives no
key presses. It doesn't matter what filetype, i.e. editor is used (I tried
Text, XML, Java, JSP).
This does not happen when the file is opened by a double click in the
(Package) Explorer view neither using the "Open Type" dialog (for Java
files).
The bug also occurs when a file (e.g. foo.xml) is already opend (in the
background) and another editor (with a different file) is focused (in the
foreground) and the first file (foo.xml) is re-opend with "Open Resource".
It does not occur switching editors (using the Command-E shortcut).
Sebastian
Re: Editor has no focus after "Open Resource" [message #336038 is a reply to message #336027] |
Thu, 14 May 2009 12:42 |
Ben Vitale Messages: 247 Registered: July 2009 |
Not able to reproduce on XP. Don't have a mac to check with.
Since cocoa support is new for 3.5 you probably should open a bug
against Platform UI. If its an SWT bug then they will reassign as
appropriate.
Cheers
Ben
Sebastian Beigel wrote:
> clean install, new workspace) I've noticed a bug using the "Open
> Resource" dialog. After selecting a file, the according editor opens and
> the file content is shown but the editor pane has no focus. The first
> line is highlighted but the cursor/caret is invisible and the editor
> receives no key presses. It doesn't matter what filetype, i.e. editor is
> used (I tried Text, XML, Java, JSP).
> files).
> the foreground) and the first file (foo.xml) is re-opend with "Open
> Resource".
> Sebastian
FUDForum. Page generated in 0.03375 seconds
