Home » Archived » BIRT » Does BIRT 2.2 support "named" parameters of data sets?
Does BIRT 2.2 support "named" parameters of data sets? [message #335951] Fri, 25 January 2008 10:17 Go to next message
I saw a few postings in the newsgroup about this with no direct answer. Is
there a way in BIRT 2.2 to use named parameters in data sets? The APIs and
the help pages imply it is doable, but when I tried to do it in my custom
ODA driver, the parameters are only bound by "position" and not "name" in
the query implementation. The only work around i could think of is to ask
the user to use a naming convention in naming the params (that include the
position) like "param1, param2...etc", which is ugly. If there is right way
to do this properly? If not, is it scheduled to be done in an upcoming
version of BIRT? I appreciate your help.
Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #341196 is a reply to message #335951] Mon, 28 January 2008 21:05 Go to previous messageGo to next message
Maged,
Support of "named" parameters defined by an ODA driver has been added since
BIRT 2.2.1.
See the comments in Bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122194#c7 on the specifics.
Linda
"Maged Elaasar" <melaasar@ca.ibm.com> wrote in message
news:fncuj9$9dh$1@build.eclipse.org...
> Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #341271 is a reply to message #335951] Mon, 28 January 2008 21:05 Go to previous messageGo to next message
Maged,
BIRT 2.2.1.
Linda
> Maged
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #1814994 is a reply to message #341196] Mon, 23 September 2019 15:20 Go to previous messageGo to next message
I am able to create report in /report folder using report api.
but when i am trying to display it it's giving me this error
"Apr 28, 2008 5:12:26 PM org.eclipse.birt.report.engine.api.impl.ReportDocumentWriter saveDesign
SEVERE: Failed to save design IR!"
but i am saving it using
designHandle.saveAs(rPath+"/sample.rptdesign");//need to un comment
designHandle.close( );
but still while displaying it's giving this error.
Actually when i m trying to display using run servlet it's working fine but using
frameset it's giving me above errors.
vidmate apk
so will u plz let me know what exactly is going on there and how can i resolve itshareit apk
[Updated on: Thu, 10 October 2019 15:12] by Moderator
Re: Does BIRT 2.2 support "named" parameters of data sets? [message #1821242 is a reply to message #1814994] Fri, 07 February 2020 16:41 Go to previous message
what's that? VidMatehttps://canlimacizle.win
[Updated on: Fri, 28 May 2021 14:26] by Moderator
Previous Topic:Value Inside Bar
Next Topic:Mosquitto 1.5
Current Time: Thu Mar 13 17:28:42 EDT 2025
Powered by FUDForum. Page generated in 0.03165 seconds
