Home » Eclipse Projects » Eclipse Platform » Core expression, adapt to inner class
Core expression, adapt to inner class [message #335871] Thu, 07 May 2009 10:24 Go to next message
Hey,
I'm trying to use the <adapt> element in a core expression, where the
target type is an inner class. So that looks like:
<activeWhen>
<and>
<count
value="1">
</count>
<iterate>
<adapt type="com.example.Outer.Inner">
</adapt>
</iterate>
</and>
</activeWhen>
That doesn't work. I also tried type="com.example.Outer$Inner", doesn't
work either.
Using type="java.lang.Object" and then adapting programatically inside
the handler's execute method works fine for test selections, so I'm sure
I have some objects for which the handler should be active..
Hope that someone can help.
Felix
Re: Core expression, adapt to inner class [message #335872 is a reply to message #335871] Thu, 07 May 2009 10:44 Go to previous messageGo to next message
Hm it must be some other problem. I extracted the inner class to be a
toplevel type and the handler remains inactive. I just read that the
expression returns not loaded if
"either the adapter* or the type referenced isn't loaded yet"
This is what probably happens in my case.
*) But I don't understand to which "adapter" the above phrase refers to.
Thanks for help,
Felix
Re: Core expression, adapt to inner class [message #335877 is a reply to message #335871] Thu, 07 May 2009 13:27 Go to previous messageGo to next message
<adapt .../> does not use the IAdapter#getAdapter(*) interface. It only
uses org.eclipse.core.runtime.adapters and IAdapterManager#getAdapter(*)
Do you provide an adapter factory for the adapter manager?
PW
Paul Webster
Re: Core expression, adapt to inner class [message #335883 is a reply to message #335877] Thu, 07 May 2009 13:55 Go to previous messageGo to next message
No... *crying*. Thanks so much for telling me this :-)
Any reasons why the IAdapter interface itself isn't considered?
I might have been able to nail the problem down with a proper debug
entry point for the evaluation of such core expressions. Any Tip?
Thanks again,
Felix
Re: Core expression, adapt to inner class [message #335885 is a reply to message #335883] Thu, 07 May 2009 14:06 Go to previous message
It has to do with class loading. o.e.core.expression is a pretty
low-level plugin, and so when you want a core expression to adapt to
"org.example.MyClass" o.e.core.expressions has no way of turning that
into a Class<?> object ... it can't see the class loader that can load
it by default. But that's just a technical problem.
There are potentially ways around it, but they either aren't reliable or
they would cause massive plugin loading on their first evaluations.
There is tracing available for core expressions, in the Tracing tab of
the launch config dialog. I'd try there first.
Paul Webster
Previous Topic:Can't use Install Software and can't run some plug-ins on 3.5 M7 release
Next Topic:How to correctly save the workspace..
Current Time: Sat Oct 18 17:21:52 EDT 2025
Powered by FUDForum. Page generated in 0.04755 seconds
