Re: Can builder change delta? [message #335895 is a reply to message #335866] |
Fri, 08 May 2009 06:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Walter Harley![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipse%40cafewalter.com) Messages: 847 Registered: July 2009 |
"Johan Van Noten" <johan@qootec.be> wrote in message
news:7566a3ea46a0adc037386d5617ed6417$1@www.eclipse.org...
> My intention:
> I'm planning to introduce an additional Builder in front of the normal
> build chain (CDT in our case, but that is not very relevant). This Builder
> needs to patch the source files, next the normal build chain should build
> as usual.
> My problems:
> * It doesn't feel 'right' to use a builder that takes a file, patches it
> and saves the same file. Typically you would expect a builder to take a
> source and generate a new artifact from it. Am I abusing the
> IncrementalProjectBuilder here? Should I handle the requirement of
> "in-place modification" in another way?
> * Moreover, my builder could need to go and change files that were not in
> the original delta. This means that Eclipse calls my builder with a
> certain delta, next my builder modifies some additional files.
> Unfortunately, the next builder seems to get the same delta as my own
> first builder. The delta is not adjusted "along the way". Is this normal?
What will you do if the source files are read-only, as they might be in a
"pessimistic" version control system such as Perforce?
I don't think you can change resources during a build. I think you may get
a deadlock, as the builder has a lock on the workspace. I'm not sure about
that. Regardless, I am pretty sure you won't be able to change deltas
mid-build.
Can you build your modified source files to an intermediate location,
instead of trying to overwrite the existing ones?
Re: Can builder change delta? [message #335956 is a reply to message #335866] |
Mon, 11 May 2009 14:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Johan Van Noten wrote:
> My intention:
> Builder needs to patch the source files, next the normal build chain
> should build as usual.
> My problems:
The only other option I can think of would be to do the "patching"
during save (as opposed to waiting until a build). If you have your own
editor for thses files, that is pretty easy to do in its save method(s);
if you're relying on a built-in editor it might not be so easy. I know
the Java editor has the notion of "save actions" or "save participants"
so perhaps that is a platform-general thing (as opposed to a
JDT-specific thing) that you could investigate...
> in the original delta. This means that Eclipse calls my builder with a
I don't know if altering the delta mid-stream would work or would be a
good idea. But if you touch other resources, that should just generate
another delta that will in turn trigger another build. You'd have to be
careful to avoid infinite loops of builds continually modifying
resources that trigger more builds.
Hope this helps,
Eric
FUDForum. Page generated in 0.04493 seconds
