Re: Help required on org.eclipse.osgi [message #335905 is a reply to message #335836] |
Fri, 08 May 2009 13:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: jacek.pospychala.pl.ibm.com
Hi Shilpa,
Eclipse uses the configuration\org.eclipse.osgi\bundles area to cache
plug-in contents such as JARs or OS libraries, that normally cannot be
accessed from JAR - e.g. JAR in JAR, or DLL in JAR. Only contents of
Plug-in classpath are extracted and it's all up-to plug-in developer
configuration.
Eclipse also transparently handles access to resources in both locations.
Similar problems are usually caused by incorrect access to resources in
plug-in, for example using classloader instead of Bundle.getEntry() to
load resources.
shilpa pisze:
> I have written a plugin that uses some resources on runtime. These
> resources are bundled within the plugin jar itself.
> As some of these resources were missing at the actual runtime, I did
> some investigation and found that resources from my plugin jar has been
> copied to a RAD specific folder at location "C:Program
> FilesIBMSDPconfigurationorg.eclipse.osgibundles"
> Also, the resources are not complete. That is, this folder has copied
> only a few resources from my plugin, not all that I want.
> This causes an inconsistent behaviour of my plugin.
> Does anyone know what the underlying problem can be ??
FUDForum. Page generated in 0.03292 seconds
