Re: Initializing Java Tooling after starting Eclipse [message #336059 is a reply to message #336057] |
Fri, 15 May 2009 23:29 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
JDT is the java compiler. If you do no java development or debugging at
all then you don't need JDT.
If you are using the Eclipse as an IDE then you probably will doing java
or starting java applications.
Thomas Wiedmann wrote:
>> If you have JDT installed it will do some initialization in the
>> beginning in order to be ready to deal with your Java projects. Don't
>> install JDT if you don't need it. Of course most of the packages come
>> with JDT installed...
> What are JDT; when are they required (and when not)?
> How can I determine, whether JDT are installed?
> How can I uninstall them, if they are installed?
> Thomas Wiedmann
Rich Kulp
FUDForum. Page generated in 0.03150 seconds
